Deck belt flopping like a fish on new zero turn
dis360
Just purchased a new Troy bilt Mustang Z 42 zero turn little over a week ago, got it home performed the initial set up, checked everything, started it up and drove it around the yard for about 30 minutes. Runs and drives very smooth and quiet, before putting it away I decided, I would check how smooth the deck is on a brand new mower, I have a Troy bilt Bronco made in 2013 to compare it against, as soon as I engage the electric PTO, waited for the blades to spin up, I said to myself that’s not a smooth running deck, it’s bouncing up and down and left and right, I gotta look at the belt and you can see that it’s just flapping around too much moving the idler pulley too much, moving the tension spring back and forth, it creates almost like a low frequency oscillating vibration, the belt is flapping a lot of between the deck and the electric PTO in the rear and just all around the idler pulley on the deck. I decided to check everything I could, checked every single idler pulley, blade spindle and all the bearings. Everything‘s tight normal nothing‘s bent, checked that the blades aren’t bent or missing any pieces. They look fine checked the non-adjustable tension spring, it’s got plenty tension on it. I checked the rear pulley on the engine, looks good, nothing stuck inside any of the pulleys. I took the belt off checked for defects and if it is the correct model, looks good. Kinda out of options here, I called Troy bilt and explained the issue. They want me to go about an hour away to the closest warranty service center which is really difficult, I don’t have a truck or a trailer. I’m hoping someone might have an idea of what I can do. I was really planning on uploading a short clip of the vibration as it’s very obvious , I will have to figure out how and update the post.
Video 1: https://drive.google.com/file/d/1DloK2Z6yVZ7zyvbMRWHp7fkM9pydfZea/view?usp=drive_link
Video 2:https://drive.google.com/file/d/1r5L-5WLmASNysDZkZ-EX2E-bp3LZ7AhX/view?usp=drive_link
View attachment 74602View attachment 74603View attachment 74604View attachment 74605View attachment 74606
Sounds like belt tension is not tight enough. Whether you go 5 minutes from your house, or one hour, you are going to have to get mower there, or have picked up. Lots of people with no truck or trailer have this issue. If you can’t figure it out, going to have to get it fixed.
Have someone sit on the seat and run the blades while you look at deck in action on your hands and knees.
+1 on checking the idler tension.
There should a mention of how to adjust the tension in the operation manual.
Also, check for any abnormalities in the belt.
New belt with hardened areas from sitting a long time (waiting for machine to be sold) and new paint creating excess friction on the pullies would be my observation.
Sit on it with the engine on high idle and the deck engaged for 30 minutes. If it does not start smoothing out, then plan on having it taken back to where you bought it from.
I do wish there was a way to adjust the tension, it’s a fixed connection on each end of the spring. The manual doesn’t even discuss adjusting it unfortunately. Maybe I should take belt back off and measure it, I have had a belt on my old mower be out of spec on the length.
Good tip, the mower was manufactured in Jan of this year. I suppose I could purchase a new belt if things didn’t smooth out after running the deck for a time.
