Husqvarna TS 354XD Fan Blade Replacement
Bruce Tee
Hello, I’m trying to replace the hydro fan blade on my Husqvarna TS 354XD Garden Tractor but all YouTube videos illustrate a model where the battery is removed from under the seat to easily access the fan but, my model has the gas tank under the seat, blocking that access.
With the deck removed there is very little clearance to remove the 15mm nut, but the drive pulley has to be secured even if a long handled wrench has the needed torque to loosen that nut.
Any advice or suggestions?
Thanks,
Brucr
Remove the deck, then jack it up to remove the drive belt enough to drop the transmission for access to the cooling fan. Sorry, there are no quick shortcuts to do the job right.
Hi O.,
The way I read it, he wants to replace the fan.
