Deck lift not working.
beaverplt
Hi all,
It's been some time since I've been on the forum other than browsing. Anyway. I recently bought a 2020 Simplicity Conquest model 2691676-00. Yesterday the electric mower deck stopped functioning. In testing, I found the motor on the deck is not getting power. When I push the lever in either direction it sounds like a motor running, but the sound is under the battery, not from the motor on the deck. I followed the wiring to the large wiring loom that runs under the battery. Can anybody direct me where to look? Thanks
Update. The motor on the deck works. I ran power straight to it from the battery to it. At the very least, I have a way to move the deck up or down.
Here is a parts source that may help you. Most likely suspect is the contactor that powers the actuator.
Are you thinking it needs replacement, or possibly some grime is messing with contacts? Thanks
