stushug
I have an srm-225 that died while in use. It's only about 4 years old. Tried changing plug first, no luck. Checked for spark and found that the coil was bad so I replaced it (yes I set the air gap correctly during installation.) I also cleaned the spark arrestor screen. Now it has a spark and seems like it wants to start but it only runs for less than about 1 second. The next step was fuel. I replaced the carb, fuel filter and lines, and the air filter. Same problem, it runs for about 1/2 a second. Not sure what else to check. There is fresh gas in the tank also. Any suggestions are greatly appreciated. Thanks in advance!
