This is a push style weed- eater, trimmer. I didn't pull the flywheel because the notch and key looks to be in alignment. I have a puller and can get it off, but why would I pull it if it's still lined up??I would appreciate your removing the flywheel please. I have found the key looks okay until you remove the flywheel.
If you’re getting an inconsistent firing the spark timing gets my focus.
I understand this is a push mower?
