Hard to start
The compression release is on the intake valve.
set the intake valve lash at .003 with the piston 1/4 inch past TDC on the COMPRESSION STROKE.
If it still hangs insert a .002 feeler under the rocker so as to take the lash to .001 and test crank thru with the spark plug cable disconnected. I've seen some start and run at .001-.002 with a broken comp relief or a worn cam lobe is why I said to leave the ignition killed when testing. You are only testing the crank through.
You need to watch carefully for the intake valve rocker arm BUMP that auto doc's mentions with the intake lash at .003. The short bump on the intake is what DUMPS some compression just little before the piston reaches TDC allowing the starter to crank through the compression stroke. The valve recloses after the bump/dump allowing for enough compression to start and run at TDC.
You can find You tube video that shows how to watch for the momentary bump.
I'll double check for the bump! Also, I was thinking about what you said and maybe adjusting the valve to overcome the issue. I might try that too. I've so far only been adjusting to factory specs. Thanks everyone for the suggestions. It'll be a bit before I can work on it again.
What I do instead of WASTING time IMMEDIATELY adjusting intake valve lash when I FIRST encounter SUSPECTED valve lash issues, instead of immediately adjusting the intake lash with tools, I just check using feeler gauges and whatever it gauges, for example
.006, I just insert a .003 gauge to take the INTAKE lash to specs and crank test using the feeler gauge to bring lash within specs or even slightly less.
If it cranks through ok I know that adjusting to specs should be a go.
If it don't crank through I look for the bump. If I see the bump the electrical system needs checked, battery, starter, etc because it's getting the dump.
With experience you can feel the dump when rotating the engine flywheel manually instead of electrically.
You're saying leave the feeler gauge in while you turn it over? How do you hold it to stay? Or do you just prop it up?
Yes, leave the feeler in place if you want to save lots time at first.
You can crank the engine with a 1/2 inch ratchet on the flywheel nut to SLOWLY turn the engine and watch for the intake bump holding the feeler gauge in manually held in place first with lash in specs then gradually reducing the lash.
You have options about how to crank engine with feeler in place to see if the engine will spin through with reduced compression..
Get a helper, (if possible) or
crank electrically if no helper by using the starter solenoid electrically. (best way)
Jumper 12v to the starter or
Remove the flywheel screen and spin the engine using a 1/2 inch drive ratchet on the flywheel nut
I do not have a helper so I rig the machine electrically with jumper wires or cables so I can hold the feeler in place and engauge the starter.
Make sure the ignition is killed. If the engine starts it will immediately pump lots of oil.
You will find on some of the Briggs engines especially ones that have several hours of use that you can adjust the valve lash to specs, spin the engine a few times and recheck and the lash has changed and REQUIRES more time fiddling around adjusting again.
The above procedure saves lots of time to see if a correct valve lash is going to correct a engine crank through.
I've seen NEW Briggs cam's fail quite often. They are wimpy made. (not a very good engineering design)
Just some more general info about your engine:
Another GOOD reason you need to REALIZE is IF the compression release on the camshaft is broken, chunks of metal pieces is being churned in the engine oil sump and WILL EVENTUALLY make their way into gears internally and completely ruin the engine.
If you do not see the compression bump you should not attempt to run the engine.
If you take a engine apart to replace for example the camshaft you need to MAKE SURE you retrieve ALL the broken pieces. I make sure I have all the pieces like putting a bunch of puzzle pieces together.
Perhaps it's not that because I've been running it for 3 years now with the issue lol. Just getting tired of it. I adjusted the valves successfully the first time and it worked like a dream but every time I've tried since it just wouldn't take so I began to think compression relief. It'll be a couple weeks before I have a chance to fiddle with it but I appreciate everyone's advice.
Just another hint to not overlook.
May not be your issue but just saying, it's not always the mechanical release that causes issues.
I've seen some of the Briggs single cylinder Intek cam's that the cam lobe wears down. Not enough lift..
Seen one that was almost completely round.
the compression release lives on the cam gear. There are two cams depending on when the engine was built. One is NLA and the other $123. The other alternative is to buy a new motor for it. The cam is not all that hard to replace, pull the engine and then the sump. Put everything back together. It is like 8 or 9 bolts. Then adjust the valves when done. If it is laying on its side, the lifters won't even fall out. If they do, keep track of where they came from. Might have to replace the sump crankshaft seal too if the rust on the crankshaft damages it. Hardest part is scraping off the old gasket and cleaning the sump cover. Date code is on the engine. It reads YYMMDD-factoryID The serial numbers are not numeric when ordering parts. An engine that starts with say 11 was made in 2011. An engine starting with 99 was built in 1999. The 11 number is newer than than the 99 even though a serial reading 990612XX might seem newer than one reading 111203XX.
sgkent, can you tell me if or what was different between the two cams and what period of time this change was made?
I have a B&S 17.5 hp MODEL 31R907 0053 G1 Ser# 070227ZA 64924. The decompression device cratered on it and wouldn't push past TDC. I have installed one after market and one OEM camshaft with the part numbers B&S shows in the parts manual. Neither one has helped the situation. It appears that the 2 replacement cams have been hitting the release way to soon to get past TDCI have adjusted the valves every way but loose and still no go. My next plan of attack is to replace the rocker arms and push rods to see if that cures the issue. That is unless I can find good helpful information to cure the problem. Thanks in advance.
Same issue: I have a B&S 17.5 hp MODEL 31R907 0053 G1 Ser# 070227ZA 64924. The decompression device cratered on it and wouldn't push past TDC. I have installed one after market and one OEM camshaft with the part numbers B&S shows in the parts manual. Neither one has helped the situation. It appears that the 2 replacement cams have been hitting the release way to soon to get past TDCI have adjusted the valves every way but loose and still no go. My next plan of attack is to replace the rocker arms and push rods to see if that cures the issue. That is unless I can find good helpful information to cure the problem. Thanks in advance.
Your engine takes the 793880 supercedes to 84005207 camshaft for all date codes.
