Using a stepped blade in a timecutter that uses a arched blade?
OldNoob
Hi all .. Just wondering if there is any advantage to using a stepped Honda blade to replace my arched blade in my 38" Toro .
Would the be any noticeable effect on the evenness of the cut? I man clearly there would be less mulching.Thanks.
Evidently, your particular Toro only offers one type of blade for that mower.
Dimensions: 19.25" Long with a 5/8" center hole
Toro: 88-5140-03
Rotary: 6184
Stens: 345-165
That's the sorts of things that are common with odd ball sized mower decks.
