McTurff
- Jul 12, 2025
- 122
NoAre you talking about where the intake bolts to heads? That is a critical area to get sealed.
Just the two gaskets under carb that sandwich the riser off manifold
I knew i would need new gaskets having taken carb iff so many times!
Easy fix
Then move on to tuning!
