loadedmango
- Aug 7, 2026
- 3
Question for yall...I just got a scag 32" mower with the Kawasaki FS481V motor. When I got it it was on one cylinder because the valves were out of spec and one of the valve adjustment collars was split.
After addressing all that she starts 1st pull no choke cold and hot every time and runs without a hitch with full power and mows great. However as soon as it is warm there is a lot of grayish smoke. The oil is fresh and filled just a smidge below the full mark with the cap not screwed down.
I did a leal down test on both cylinders and got <5% leak with hissing from the oil fill and no noise from intake or exhaust.
I just changed the fuel pump thinking the Diaphragm must have a hole but no change.
My next thought is head gasket or piston rings but I am thrown off because of the leak down test...any thoughts?
