whell bearings
johnny mc
i have a scag sfz48-22kt does anybody know where i can get aftermarket wheel bearings and are they anygood they are for front wheels
Well that model Scag IPL does not any bearings for front wheels. Several close models show plastic bearings along with a couple seals.
Does yours have the plastic bearings? IF not then what are bearing ID, OD, and thickness?
thanks i will find out
do you happen to know if there are any of these aftermarket wheels and tires are any good
No I don't, just to help out on the bearing issue. I pretty sure the if regular bearings they will the flange type with an extension on the inner bearing piece. Just got find out the dimensions needed. As said your particular model IPL doesn't list the bearings as a separate item.
For some reason Scag here are a rare breed. I got a couple Turf Tigers under my wing but no Freedom Zs.
An AI search will give you an answer. However, I wouldn't completely trust that. The best way to get your answer is to pull the bearings and seals then match with new stuff.
Okay looks like the plastic bearings are 1-3/8 OD with a 1" ID base on the seal size. If this correct and the space between the forks is 6" then they can be converted to flange ball bearings and a new spacer tube. These parts would be from Bad Boy and Scag or their generic versions.
Currently these wheels appear to have a 5/8" with a spacer tube that is 1" OD and you need change to 5/8" OD tube.
