Fuel gauge float don't float
well known issue with all kinds of fuel floats since they moved from brass to that hard foam plastic. The foam absorbs the oils in the fuel and gets heavier. Just replace it with a new one and budget for it every three years. No need to rant. It is a industry wide problem when that hard foam that feels like plastic is used. Or find a way to adapt a brass or hollow hard plastic float.
