bronxmcmullen
First time owner of a toro zero TORO Zero Turn mower bought used, Model 75212 built May 2017. I purchased for the comfort of the My Suspension System it had due to several spinal surgeries from leaving service. Drive belt came off I was able to reinstall drove came off again in several feet so bought a new TORO OEM Drive belt same problem. It feels like belt is to big or tension is not tight enough. One thing I have noticed is rear tires look slightly toed in. Anyone Having same problem or can offer any advice I would much appreciate it.
