Auto Doc's
- Sep 7, 2024
- Threads
- 23
- 1,949
Hello R.,
Has luck would have, my power went out due to a tripped main breaker in the outside main power box this evening and I figured I was good to start up the 15KW Generac and power the house.
After running for a couple of minutes to warm it up. it started weeping oil out of the fuel pulse pump brass vent on the top.
That was weird and I have never dealt with that before.
Being at 40 degrees and rainy, I was in no hurry to figure it out this evening and I was able to reset my outside main breaker without issue.
I will make a separate posting about this as this unexpected discovery unwinds and the weather get a little warmer in a few days.
