Carburetor needle seat cleaning
Auto Doc's
Hello Folks,
Carburetor cleaning can be a chore, but sometimes it takes more than just good carburetor cleaning and a round in the ultrasonic bath. I try to save what carburetors I can to avoid aftermarket copycat versions.
For those that hate Nikki carburetors, I will simply say don't open them unless you put a complete rebuild kit in them. I work on many mower carburetors, but also ATV and automobile carburetors. I've been rebuilding them for many years. But, once in a while I run into one that will give me headaches.
Last week I was working on a problem carburetor on a 2003 Honda Rancher 350 ATV, and it was giving me fits. It has a press in needle seat. No matter how I adjusted the float level it would eventually spring a leak at the bowl overflow.
Finally, I got online to check out some of The You Tube videos and a guy brought up and interesting procedure for cleaning the needle seat and polish it in these ATVs.
Over time gasoline develops a resin or shellac and that stuff is difficult to remove even with the best carburetor cleaner. The solution he came up with was to use a Q-tip with the carb spray. Insert the Q-tip cotton tip into the seat and gently spin it. It cleaned and polished the seat perfectly.
It worked great and I had no more needle leak problems.
Hope this helps someone.
I don't think this same method would work on any 2-stroke handheld carburetor because the parts are way too small.
Tiger Small Engine
Hello Folks,
You can also put a wooden Q-tip with valve lapping compound on it and chuck it up in a drill at low speed. Then switch to carburetor cleaner, then blow out the seat.
Scrubcadet10
Moderator
Staff member
Yep, I always Q tip the seat really good
Auto Doc's
The one design I forgot to mention is the carburetors with the Viton seat insert that has to be pressed in. I have not found a good way to clean them, and they are a pain to work with if a new seat has to be installed.
Most of the ones I have come across have the needle stuck badly from old, dried fuel resin and are seldom worth the effort to save.
Doc, I assume you are referring to Tecumseh carbs with the replacement seats. Personally I have found these are about the easiest carbs to clean and rebuild. Removing and installing a new seat can’t be easier if you have the correct tool. One thing I have found through experience is to always install the new seat dry. For some reason when I first started teaching carb rebuild, adding a small amount of oil resulted in leakage. Never found out why, just always installed dry with no more problems. Here is the tool.
hlw49
I take shop air and stick it in the fuel line fitting of the carb and blow it out. Tool works great to install it.
Auto Doc's
Hi Rivets,
I seldom see Tecumseh in my area, but I have dealt with a few small B&S models with replaceable seats.
Usually when I get those, they are salvage or yard sale finds that have been sitting for years with old gas in them.
My memory is fading, but I can’t remember ever seeing a viton seat on a Briggs engine. Now replacing a brass seat on Briggs is a different story.
hlw49
Made a puller to pull them out on Briggs and Kohler carbs with brass seats Kohlers new seats are Zinc and alcohol fuel won't damage them.
