Westinghouse and Duramax generators
Zzz
In the event I don't repair my Briggs & Stratton defender 8250 generator, I saw some good prices on Westinghouse and Duramax electric start generators and wondered what you folks thought of those brand names. Thanks
Auto Doc's
Hello P.,
What are you planning to do with the generator? If it is for emergency standby? Anything below 12KW running watts is a waste of money in my opinion if you need to run heat or AC.
Do you plan to use it for jobsite work?
Bigger generators are heavy, but they have to be to produce adequate power when needed.
Personally, I prefer the older Generac portable models.
Most generators are made in Asia, regardless of the brand name on the machine anyway these days.
Whatever you choose to go with make sure to pay attention to the running wattage, not the max wattage. The bigger number is always the surge wattage.
Max wattage is only for surge loads to prevent stalling out the generator engine. A generator does not run at maximum wattage on a steady basis. Manufacturers play rating number games to make the consumer think they are getting more than they actually are.
Even much of the newer Generac generators are made overseas:
Zzz
This would be to run the whole house for whatever length of time was necessary. Dual fuel is a good option and the electric start is a plus. The price point is a plus right now. Looking at my Briggs & Stratton 8250 generator isn't really enough to power what we had but it's been good in a pinch. Since we have three ways of warming the house and only two require electricity, it's gotten us by.
Auto Doc's
Hello P.,
This is only a 10,500-Watt steady power unit. That is too small to run a whole house in my opinion. People often pick too small of a generator to save money. I am not trying to talk you into spending more, but a bigger generator is advised.
To run a whole house, I think you need to invest in a larger unit around 14 plus KW continuous output.
Gas models are usually preferred due to availability most of the time, but plan on having fuel standing by fuel before the weather gets desperate.
I have gone through some rapidly changing weather (cold and hot) here in South Texas where the power went out for days. I thought I was good with a 9500-Watt generator only to find out that I was sadly mistaken.
After we had an historical freeze for a few days about 3 years ago, I upgraded to a 15KW Generac portable generator that could handle the power load of an entire house, especially heating and cooling. I added an inlet box & 6/3 cable and wired directly to my main breaker box. For safety I installed a 60A breaker and a lockout so I could power only off the generator without back feeding the main power supply line.
During past outages, I have also had to resort to removing fuel from my vehicles just to run my generator. It's not easy getting fuel out of modern vehicles without some creative engineering.
Now I keep two 14-gallon portable fuel tanks full/ with stabilizer and a 12V electric pump with hoses to refill my generator as needed. When my power goes out, the area gas stations are also shut down.
Propane will have a higher fuel consumption rate and lower generator output, so don't expect getting ahead using Propane, I only use Propane has a last resort when my standby gas reserve is depleted. On Propane, I had to run limited amounts of time to conserve fuel after heating or cooling my house.
Are you planning to have power for heating and AC? That will take a majority of the generator output.
As a minimum, mark your calendar to run the generator once a month for 30 minutes to an hour to maintain it and the fuel does not sit for too long in the carburetor or the tank.
Here is a good generator calculator to use:
https://www.primalsurvivor.net/what-size-generator/
  • Like
Reactions: Zzz
Zzz
Thanks for the in depth info! I really appreciate the time you took to help me make a good decision! Thanks again
Scrubcadet10
Moderator
Staff member
My grandad has the duromax 13000 watt from Lowe's, propane or gasoline. Had it about 4 years now, starts it up once a month, runs it for about 30 minutes.used it for 4 days straight after Hurricane beryl. No issues.
Auto Doc's
Hello P.,
I help folks in my area with generator issues and sizing quite often. It amazes me how many people do not understand generators and think that if a generator can power a circular saw, it can run a whole house.
Big "starting wattage" numbers in advertising have tricked many people, especially in recent years. Steady running wattage is the most important number for reliability.
Marketing often takes advantage of ignorance to sell more cheap products.
The truck commercials are another "false advertising" for the trucks that come with a power invertor. Those power inverters are only good for a limited number of low wattage lights. Flip on the heat or the AC while connected and they will be calling the fire department pretty quickly.
If your heating and AC take priority, read the startup wattage and amperage on the information plates of the outdoor unit and the indoor air handler, then add 10% to that total. That is an equation that works very well.
Cutting off your electric hot water heater circuit breaker if hot water will not be needed for a few hours also helps.
