Cub 1330 belt idler
tim4
I am working on a Cub 1330 where the person put the arm that has the idler wheel for the belt tensioner for the mower drive belt in the wrong place. I know it is bolted to the under frame of the mower. I reattached it to the threaded hole on the mower chasis but I can't find a hole for the tension spring. I have the the idler wheel toward the pulley on the mower deck.
Auto Doc's
We need the product label information.
A couple of pictures might also help. By brain is having trouble focusing by using my imagination to "paint a picture" of this problem.
Pick one:
On this particular CC it has a separate deck model number which appear to be a 38" deck.
Deck secondary belt setup
Primary PTO and Drive belt idlers connections.
tim4
Thank you I fixed the problem.
