Catenary Kid
- May 7, 2023
- Threads
- 7
- 21
Some time ago I discovered my 2013 Prestige steering cylinder was leaking. I purchase a replacement (Simplicity Snapper Cylinder - Hydr Steer 1737057YP) and am now trying to do the change. Getting the cylinder off the frame was easy, but I was astounded at how difficult it was to get the hydraulic fittings out of the cylinder! The only way I could do it was to crack the fittings loose with a wrench, then rotate the cylinder around 360 degrees several times, passing the hoses over and under each other, then untwisting them to get the threads undone. It took me over an hour to get it disconnected, which should have been a 10 minute job. Apparently, there is no swivel feature on Simplicity hydraulic hoses? The fittings are 90* connectors with male threads going into the cylinder body. There is a threaded nut that connects the hose to the cylinder but it is threaded inside and out, and will not turn (loosen) enough to allow the threads to exit the cylinder casting before jamming.
Someone please tell me I am missing something here and it really won't be a 2 hour contortion fest trying to get this back on? Has anyone ever done this before? At my wits end, methinks....
