Scag Wildcat crank, no start issue
Rustbox F700
I have a scag wildcat model number STWC52V-26KA/ serial number C6600168 with a kawasaki FD731V 26hp. The mower was not charging the battery and I found the main harness connectors were falling apart. I got rid of the plastic connectors that were brittle and falling apart with heat shrink butt connectors in their place. Spliced each wire individually so nothing got crossed up. Mower started properly but was still not charging, found the fuse by the ignition switch was blown, replaced it and started mower. Charging system is working properly now, moved mower a little bit and shut it off, went to start mower again and it would not crank at all. Checked safety switches and they appeared ok, ran a ground wire to the interlock module to the green/black wire and mower cranks no but has no spark? Any help would be appreciated on what to check next.
Its Me
I know it a lot of trouble but remove the shroud and take the kill wires off the coils, that could tell you that you have a ground wire or even dead coils.
Rustbox F700
Ok Ill try that and see what happens, thanks
Rustbox F700
Coils checked out good, found it will start only with the choke fully on, going to go through the carb and clean it
Solder and marine grade heat shrink is a nice way to terminate properly. Marine shrink has a glue inside that ooozes out and seals the bond from the atmosphere.
What RPM do you mow at? Do you ever idle it down?????????
All those cranking attempts will drain the battery. No wonder it didn't start back up.
It takes several (15) minutes at MAX revs to "nearly" charge a battery back up. Mowers do not have large alternators to immediately top the battery back up. Get a Battery Tender and use it.
Load test the battery.
Auto Doc's
Verify the fuel shutoff solenoid is working correctly. When they fail it will only allow a tiny amount of fuel through if the engine is fully choked.
