Briggs & Stratton 15.5 hp dies after it has run for about 1/2 hour
  • / Briggs & Stratton 15.5 hp dies after it has run for about 1/2 hour
Snip off the after-fire solenoid plunger tip with some dikes. Install an inline fuel shut off valve. Close the fuel off about a min prior to killing the engine. Never have to worry about it starting again.
