scag walk behind
Mack Man11
My scag walk behind starts but when i try to put it in gear or start blades it stops
Issue is with the operator presence switch, or the associated wiring circuit.
Auto Doc's
Can you provide a model and serial number off of the manufacturers label? Scag makes a lot of different model walk behind mowers.
Typically, the hand clutch safety switch or park brake switch and wiring is where to start looking.
