B&S 17 HP single cylinder starts with gas in air intake but won't keep running. REmoved carb and it had gas in it. Suspect the electric solenoid valve at the bottom of the bowl. That part is new to me. What does it do? I plugged the electrical connection with the solenoid removed, turned key and nothing happened. I assumed it would be activated by the switch.
