- May 6, 2010
- Threads
- 44
- 10,914
it looks like from briggs the 126T02-0521-B1 gets replaced with the 126L02-1005 but you have to transfer the flywheel from the original engine to the new engine and remove the 691921 rope starter and 694849 crankshaft from the replacement engine and install the 392259 rope starter and 694478 crankshaft. But it appears that the 126L02-1005 has been replace with the 104M02-0182-F1 So I don't know what the conversion would be for that engine
