Tecumseh 10HP 143-296042 Ignition How to update to non-points.
silver1
I have read that newer engines have coils that eliminate points.
Can I do that to my 10HP? If so what would be the part #?
Alternator magneto no. 610979.
LB
I am not certain, but I think Tec made a replacement coil just like B & S did. I will look in my book on Monday morning.
If I did my research correctly, you have a VM100-157034B engine with a three legged coil mounted under the flywheel. Tecumseh did not made a CDI replacement for this system. Sorry for the bad news, but maybe chance will prove me wrong.
:smile: Ditto on what Rivets posted. Plus there are no mounting legs for the coil/mag on the block and no magnet on the flywheel O.D..
+1 what Riv and Buck said, but years ago I remember seeing a small solid state module that can be easily installed. I remember putting one on an old Clinton engine. I'll see if I can find the info on it.
:smile:That module was probably an Atom, there are others but can not recall the names.
Great,. waiting for more info.
Actually after seeing if they were still available in my book, they are called "NOVA" (works with 2 & 3 leg coils). I guess I remembered 4 letters and Atom sounded familier. They cost around $15.00. Funny because "NOVA" in Spanish means "No Go". Perhaps that's why the Chevy Nova didn't do too well here in So Cal
GM tried sell Nova's in Mexico and failed:laughing:
I heard that was why.
ANy idea where to find this module?
