mowerfreak
Been reading this forum for days and couldnt find anything on this subject so I decided to register and post a new thread in regards. Just bought a brand new Snapper walk behing Hi-vac. I'm a fan of these because it's that same brand and model of mower I've used in the same yard since I was about 10 ( i now own the house I grew up in) so it is the one I purchased due to the high level of familiarity. I did the research on it before buying and noticed the few things that have changed over the years including the one that is giving me the fits and that is the speed. I know they put bigger wheels on at some point to make them faster but I dont like it. I have all the adjustments for the self propel set for it is moving as slow as possible and since I have a thick lawn it is still leaving a lot of grass uncut because it is simply too fast. I went to the place I bought it and they told me all I could really do is adjust the self propell but it is bottomed out. There has to be something that can be done or bought to slow this thing down. Im thinking of changing the crank pully for the drive belt to a smaller one but the stock one is quite small as it is. Any thoughts, or anyone else have this issue? Is it possible that I have the deck set wrong, it's sitting level. power is not a problem, nor is catching, it picks absolutely everything up that gets cut, it just leaves some uncut cuz it's too fast.
