Masonisking
- Sep 7, 2026
- 7
Just purchased a toro timecutter, it runs but not great. After running for a bit or engage the blades seems to sputter out and eventually die out.
The fuel tank is a siphon with the fuel pump sucking it from the top of the tank with a feed hose. I replace fuel filter and pump because it was only dribbling out but I’m not getting anything out of the fuel pump any more. It’s brand new hooked up identical. Not sure what else to try any ideas? The pulse is strong enough to move a paper towel not sure if it should be stronger or what.
