john in ohio
- Mar 12, 2026
- 67
I'm at 300 hours and took the heads off to clean the carbon from the pistons and check the valves. Should I replace the head bolts or re-use the original bolts?
Where should I use Loctite, I was told that the blue loctite needed a primer when steel bolts go into aluminum?
