- Sep 7, 2024
- 3,384
Hello folks,
We are bracing for rain, snow and cold conditions down here in South Texas. To be vigilant I decided to fire up my generator and not wait until the last second. Well as luck would have it the positive battery cable end repeatedly arced and had to be manipulated for the engine to crank over. (Murphy's Law at work here).
So, at 9 PM this evening before the bad weather moves in, I had to make a new cable.
I know for many of you, the weather has already been much worse, but don't forget to check and clean your battery and cable ends before the "fit hits the shan".
Batteries and the cable ends typically fail the most when you need the most.
Stay warm.
Stay warm.
