LX188 John Deer
Auto Doc's
Hello T.,
This has to be about the shortest post that I have seen yet. What have you checked anything? Do you know how to test anything?
StarTech provided a diagram. Let us know what you find
tiger29
You have any ideas do not see any seat switch on that diagram.
Auto Doc's
The diagram shows a dash marked box around the interlock module, that usually means there is more wiring to this interlock module than the diagram shows.
Has the 15A fuse been checked?
Do you have a basic test light and a multimeter?
The OP said no power to the starter not a starting up and running problem. Seat switch powers the ignition coils and fuel solenoid via relays.
tiger29
Do all safety switches activate the starter solenoid and where is the 15A FUSE?
