Model Identification Problem
bartles
Working on a "very experienced" Yard Man 38"/12.5 HP B&S
The model on the tag under the seat is: 13AT674G401(the seat must be from another model MTD)
The tractor has a totally different deck belt/pulley arrangement than what is illustrated in the MTD website. This tractor has the cable activated
deck belt tightening method via a lever on the right side of the body next to the deck height adjustment lever
so.............is there another place to look on the tractor to locate the model number?
I need to order the spindles, blades, and the belt tightening pulley,
I appreciate the help,
bartles
Get the model type and code from the Briggs engine. Sometimes those numbers can be used to narrow down and reference a few models that was built that year
Yes seat is off another mower as it is off a 42" cut mower. What year is the engine? hoping it is the original engine.
13AT674G401 Yard-Man Lawn Tractor (1997)
F = 38
G = 42
H = 46
bartles
Model 28N707-(Code) 0160-01 s/n 9407184B
bartles
I appreciate your help guys!
That should make it either 134N604F401 [1994] or 135N604F401 [1995]; provided no other mods done.
Engine has been replaced also. Only 38 inch deck made in 1994 or 1995 had a flat head 28m707 engine.
bartles
I looked again... The mower body says 38"/12.5 HP B&S.....the engine is 15.5 HP OHV B&S....I got me a real "Frankenstein"
