PTmowerMech
- Apr 16, 2018
- Threads
- 442
- 3,409
this may damage the coil transistors since the High Voltage has to dump somewhere.
Correct not a good thing to pull a plug wire on some ignition systems.
Also
If you have one of these inline spark testers it will also allow grounding the the ignition while the engine is running if the spark plug boot is the molded type and cannot be slide back on the ignition wire for access to the tip of the spark plug.
OREGON SPARK TESTER Repl Briggs 19051 19368
Doesn't the same effect on the coil happen when you run a 2 cylinder on only one plug wire. As in removing one plug wire, starting it, then repeating the process with the other side?
The electricity being created by the coil with the disconnected plug wire has to go somewhere also. Right?
