Right hand side. In heavier grass it is much more noticeablewhere exactly does this 6-8" stripe appear? Left side, middle, or right side.....? A picture shooting at ground level might be better...
I suspect one of the spindles is seized a bit and/or Belt is too loose. Get it up in the air and with Blade rotation OFF, reach under and see if they rotate with equal ease. Sorry for your luck. Check what was done on last service call and get your BF to man up.I have the 60inch deck. 2024 bought new last summer. I forget the model. I can get if relevant. This issue was fixed last fall under warranty. The tech came out last fall to fix a loose bolt on the steering handles So it wouldn't start. I mentioned to him I waited my whole life to get a good professional grade zero turn and look what it does. My BF bought me this high end model with seat Suspension and everything. I show him I need to make two passes so effectively I only have a 2.5 ft deck. He did something. Problem went away. I probably only put max 20 hours on after the fix. Problem came back again this spring After around another 6 hours. If I make one pass with mower in anything higher than 4 inches I get a 6/8 inch wide stripe that hasn't been cut or maybe partially cut. I replaced blades hoping for a fix. No luck.. now I am supposed to bring it back to shop yet again or pay 150 an hour from when they leave the shop AND 1.30 per miles to have them come out again. So I will need to load on trailer and take it back over. Anyone here have any idea how to fix? Is this something permanent with this mower? I am so incredibly disappointed.
pic but needed to be much reduced otherwise too large
Ditto on the make and model #...I have had similar problems in the past if the deck belt was not routed correctly. Some decks have a belt routing diagram on them for reference.
The other possibility is the deck belt is a "generic" and/or is not the exact length. If a deck belt is not correct the blade speed is reduced, especially in heavy grass. The heavier the grass the worse the cut.
Never did see your machine information. We need the machine make and model along with the machine label information. The is no real answers without this information, just guessing and speculation.
