SF111R not starting
ueww40
When squirting a few drops of fuel into the carb it will start but dies as soon as the squirted fuel is used up. Primer bulb is filled up with fuel. Fuel filter in tank has been replaced. It ran a few days ago. Stihl dealer says trimmer is not worth fixing, it has no compression which is probably BS. I replaced the carburetor and messed with the H and L needles. Exhaust is unrestricted. If compression was the problem I guess it wouldn't start when squirting fuel into carb. Any ideas??? Btw, does this engine have compression release to make starting easier?
My concern at the beginning is what is the compression reading. Above 90 then I would consider replacing the carb and see what happens.
4180 4 mix engine.
Yes it has a decompression setup so the valves needs adjusting every so often. Now does a special feeler gauge as most are too wide to use.
I personally use a different minimum compression number of at least 100 psi.
Also the lat time I brought it was around $50 and but now you can get a repair kit for thru Amazon under RB-287. CTS has two kits for under $10 including shipping. It is mostly a stiffen metering diaphragm not allowing the metering needle to open up.
I just added those to my next purchase from Amazon myself.
ueww40
I just picked up my trimmer from the dealer and I had a long talk with the service tech who worked on it. He said he did a compression test and a leak down test and the leak down test failed miserably. He said that the compression loss is caused by a faulty exhaust valve. Now I feel newly encouraged and my nest move will be to remove the head and take a good look at the valves, valve seats, cam, push rods etc. Updates will follow.
ueww40
Thanks StarTech for the decompression info. How does it work on that engine?
It opens one slight right before TDC compression stroke. As for which one I haven't paid attention but I think it would be the intake valve.
ueww40
Thanks StarTech. I couldn't have asked for a better explanation. Before I tear into that engine I will check and make sure that the decompression nipple moves freely and is not stuck
ueww40
I got the engine apart and it looks like the Stihl tech was right. looks like a valve job will make things well again. The cylinder walls don't have a scratch on it and the piston and rings definitely look good. Also the decompress nipple on the cam is good but I may replace the cam anyway even though the old one looks pretty good. Both valves look good but the valve seats are in bad shape. Question, can I replace the valve seats? That would be great. Pop new seats in and put in new valves and that should fix my problem
Stihl only sells the cylinder with the valve seats installed.
PN 4180 020 1209 Cylinder
PN 4180 007 1036 Gasket Set
PN 4180 030 1800 Cam Wheel
But first see if you can clean them up with fine valve grinding compound via a valve job procedure. They may just be carbon up. But sometimes they are too damage to clean up.
