Where to buy OEM belts. I have a Troybilt TB 30 mower, model #13B726JD 023.
efujishi
  • / Where to buy OEM belts. I have a Troybilt TB 30 mower, model #13B726JD 023.
I am from Hawaii. Where can I buy belts for this mower? Couple places will not ship to Hawaii.
Thanks,
Earl
Check with the service center below or at least the Troy-bilt site says there is one there.
Or try one of the dealers.
efujishi
Thanks for all your heip. You made my day! I will check these places.
Aloha,
Earl
Joed756
NAPA is all over HI, you won't get OEM belts, but likely better ones.
Only way you get better belts is if you take a lot of time to identify the belt material and size. Experience has taught me to NEVER believe what the guy behind the counter says about their belts, at an auto parts store. Most don’t know the difference between blinker fluid and bacon grease.
Joed756
Well, I've had some 50 or so years of success with NAPA belts. I don't thing Troy-Bilt uses any belts but those from the lowest bidder.
Then you’ve never had to warranty your work. I learned a long time ago, I don’t want to do a job twice trying to save a buck or two. My rep means more to me and customers keep coming back.
Joed756
So you get the parts from the lowest bidder rather than the place with happiest customers. Do you really think NAPA would stay in business selling inferior products? Nuff said, I'm out.
No, 90% of the time I will use OEM belts. Only use aftermarket belts when I’m in a pinch. NAPA sells 90% of its belts for automotive use and wouldn’t survive if it relies of belts used in the small engine world.
So I did the Napa belt crossover for the OEM belts for the OP and all 3 napa belts are slightly the wrong length and 2 are the wrong cut angle
