I have a PB-500T. Serial P31212136027
I can get it to start if I pour a small quantity of gas into the carb. After it starts it runs great full throttle and low idle. If I do not pour gas into the carb I can prime the carb ( a dozen pumps or more..full choke and pull, pull and pull some more and it never even pops. I gave pulled the spark plug after and it seems dry. What am I missing? This is a Walbro WAL-1 carb. It has the odd horizontal air valve on top of the carb. I have very little experience with this style of carb.
I have spark and I have 115 lbs of compression and it runs great once it starts. It seems like the gas isn’t getting into the cylinder. I replaced the fuel line and fuel filter, I replaced the coil and this problem is with a new aftermarket carb which did not correct the same issue as the original Echo/Walbro carb.
Could I gave an aid leak somewhere?
Any ideas greatly appreciated
CFS
CFS
