FD501V-CS00
E/No FD501V061146
For some reason, this fan (just below the radiator) had one fin that had dropped down, like it got hot. And was rubbing on the fan shroud. All the others were fine. No drooping at all. So I heated it up and bent it back up, so it wouldn't hit.
Question is, is this going to work? I didn't heat it up enough to burn the plastic. I kept my finger wedged under it while heating, until I felt it give. Then held it in place until it cooled.
Here the fan blade.
E/No FD501V061146
Here the fan blade.
