Kawasaki twin cylinder engines maintenance
RayMcD
Otherthan blowing is off with compressed air, what do you do the clean the top of a twin cylinder Kawasaki engine? thanks Ray
vacuum or air but be certain the area between the engine head and the shroud is clean too . That air flow can be determined while the engine is running by holding our hand down around the spark plugs . It's possible for a mouse build a nest in that area overnight . That may not be possible for some that house the mower .
The brush reminds me of one i modified to clean Cottonwood blooms from Condenser coils .
Cut the handle off , chuck it in your drill and spin it for troublesome areas . Yes sir , i've done many things in my life other people don't do .;)
Remove engine shroud and cylinder head tins and visually inspect engine and cooling fins for dirt, grass, and debris. Use a screwdriver, wire brush and air compressor air gun to remove debris as needed. Supposed to be checked annually, although many are seldom or never checked and cleaned. I clean several engines each year this way for customers every year. Engine will probably eventually overheat if not cleaned, and then more problems and expense.
Compressed air is your best choice.
People who wash their engines are causing slow death to it.
Once a year or so, it may be worth removing the shroud and other covers to do a really good cleaning between fins.
Gentlemen, thanks, I have removed the engine cal couple time and used compressed air to blow it clean as recommended. I just wanted to make sure that was sufficient. I do like the idea of the long round brush and don't see that causing a problem. Last thing I would be inclinde to do is to flush the engine with water.
My storage building is very tight and I keep rodent traps loaded all the time as a back up. Never have I had problem them in the building, they did do terrible number on my daughter car several years back while it sat under the car cover, Cheer All, Ray
Ray- That is just if you see lots of debris between the cylinder fins. It's a very effective tool, imo.
I never use water, just compressed air.
I use a leaf blower. They are also great for blowing water off your car after a wash. It reduces water spots
Get a cat.
