If you have a heavier end and it is down when the blade is vertical, it won't move. If you put it upwards, it will rotate. Being horizontal, it will rotate either way. I have an 1\8 in rod protruding out of the edge of my bench that I horizontally balance the blades. It is level and plumb with the bench and works very well. A cheap cone type balancer did not work well for me, not accurate enough.
