murrary 17.5hp 2004 riding mower gas tank?
Justwayne
Where can i find a new 17.5hp murray riding mower gas tank? Its a 2004 riding mower but the middle seam of tank has split from aging and needs a new tank cant fill it up over half a tank. Whats the part number for a new one and best price? How hard is it to replace theres just a few screws on the top cover but the steering wheel bolt, ignition nut and would have to maneuver around the choke throttle and parking brake handles?
murray 425001X8
Justwayne we going to need the model number from serial number tag as there is more than one 2004 model.
Murray Lawn Tractors Parts Diagrams​
  • 31" Cut
    • 312001x50C - Lawn Tractor (2004)
    • 312002x11A - Lawn Tractor (2004)
    • 312002x98B - Lawn Tractor (2004)
    • 312004x68A - Lawn Tractor (2004)
  • 38" Cut
    • 385000x68A - Lawn Tractor (2004)
    • 385011x50C - Lawn Tractor (2004)
    • 385014x98B - Lawn Tractor (2004)
    • 385015x50B - Lawn Tractor (2004)
    • 385015x50C - Lawn Tractor (2004)
    • 385016x78A - Lawn Tractor (2004)
    • 385021x53A - Lawn Tractor (2004)
    • 38516x53D - Lawn Tractor (2004)
    • 387002x83A - Lawn Tractor (2004)
    • 387002x92A - Lawn Tractor (2004)
    • 387002x92NA - Lawn Tractor (2004)
    • 387003x8A - Lawn Tractor (2004)
    • 387004x48A - Lawn Tractor (2004)
  • 40" Cut
    • 405000x31B - Lawn Tractor (2004)
    • 405000x8C - Lawn Tractor (2004)
    • 405000x8D - Lawn Tractor (2004)
    • 405001x78B - Lawn Tractor (2004)
    • 405004x50B - Lawn Tractor (2004)
    • 405004x52A - Lawn Tractor (2004)
    • 405005x99B - Lawn Tractor (2004)
    • 405005x99C - Lawn Tractor (2004)
    • 405007x18B - Lawn Tractor (2004)
    • 405030x48B - Lawn Tractor (2004)
    • 405030x48C - Lawn Tractor (2004)
    • 405602x51A - Lawn Tractor (2004)
    • 405604x53A - Lawn Tractor (2004)
  • 42" Cut
    • 425000x8B - Lawn Tractor (2004)
    • 425001x31A - Lawn Tractor (2004)
    • 425001x8A - Lawn Tractor (2004)
    • 425001x8B - Lawn Tractor (2004)
    • 425002x99B - Lawn Tractor (2004)
    • 425004x99A - Lawn Tractor (2004)
    • 425004x99B - Lawn Tractor (2004)
    • 425005x8B - Lawn Tractor (2004)
    • 425014x92A - Lawn Tractor (2004)
    • 425015x92A - Lawn Tractor (2004)
    • 425016x78A - Lawn Tractor (2004)
    • 425604x18B - Lawn Tractor (2004)
    • 425604x99A - Lawn Tractor (2004)
    • 425615x50B - Lawn Tractor (2004)
    • 425615x52A - Lawn Tractor (2004)
    • 425615x78A - Lawn Tractor (2004)
    • 425615x99A - Lawn Tractor (2004)
    • 425618x48B - Lawn Tractor (2004)
    • 425619x24B - Lawn Tractor (2004)
    • 425620x92A - Lawn Tractor (2004)
    • 425620x99B - Lawn Tractor (2004)
    • 425621x53A - Lawn Tractor (2004)
    • C950-60470-0 - Craftsman Lawn Tractor (2004)
    • C950-60471-0 - Craftsman Lawn Tractor (2004)
  • 46" Cut
    • 465306x31A - Lawn Tractor (2004)
    • 465614x48A - Lawn Tractor (2004)
    • 468600x43A - Lawn Tractor (2004)
    • C950-60472-0 - Craftsman Lawn Tractor (2004)
    • C950-60473-0 - Craftsman Lawn Tractor (2004)
Murray Garden Tractors Parts Diagrams​
  • 46" Cut
    • 461004x92A - Garden Tractor (2004)
    • 461005x68A - Garden Tractor (2004)
    • 461604x99A - Garden Tractor (2004)
    • 465306x8A - Garden Tractor (2004)
Choosing 425001X8A
Murray 7601092MA Fuel Tank.​
That is why I choose the first edition of the mower.
Justwayne
Justwayne
Yeah part number is written on the fuel tank itself 94073. Thanks
Forest#2
Looks like you found a cheap replacement.
I've Plastic welded several of the plastic gasoline gas tanks with good results.
You can watch several you tube videos about such.
I try to use a piece of plastic from the one I'm welding/repairing so as their DNA is the same.
Justwayne
Its an older tank can see it had bowed out and busted at the middle of the tank seam. Im going to replace it since the mower is from 2004. I recently put new blades and carb assembly, fuel line but it is still in great condition only use it 3-4 times a year.
Thanks for your help i have a toro 6.5hp gts pushmower where after a minute after starting it fuel started running out of the air filter and it cut off. Someone told me this was a needle a seat problem. Would anyone happen to know the correct or replacement carb part number for the toro 6.5 hp gts? That way id have a new primer bulb and gaskets. It started everytime the first try before just think the gaskets that mate on each side could be replaced as well as float needle seat assembly. Or are there differentv6.5hp toro gts lawnmower models? I posted it in the toro thread section.
