Craftsman Garage
- May 2, 2021
- Threads
- 45
- 573
I was mowing after I had replaced the spindles, blades, and 1/3 idler pulleys ( they mowed freely and were in good condition and didn’t have replacements), engaged blades and the engine bogged a bit (even at high rpm) and the whole mower shook like crazy until it built up rpm, then it just shook a little bit. 10 seconds later, BANG from under deck. The belt had come off somewhere and caused a tangled mess and A keeper turned 180 degrees and bent, it looks like in the photo below. It is keeping the belt on an idler pulley. I’m clueless as to what caused both of these things to happen, maybe the belt is too small or is stretched. This is on a craftsman dgs6500 (2008 917.28848X) with a 54” deck with a Kohler courage sv-735-0016 26HP vtwin. TIA for help
