Wazza65
- Jul 10, 2021
- Threads
- 2
- 11
I have a John Deere LT150 with a 15HP Kohler Command engine (CV15S) that appears to be running rich, and the spark plug has black sooty deposits consistent with a rich mixture. I replaced the unserviceable air filter and fitted a new spark plug.
It has a Walbro carburettor that does not have a fuel solenoid, and the choke Is opening and closing correctly.
I removed and cleaned the carburettor, drained the fuel tank, and filled it with fresh fuel to no effect.
I performed a pressure test on the carburettor in an inverted position, and it successfully maintained 5psi, indicating that the needle and seat are sealed and there are no grooves on the inlet needle.
I removed the carburettor a second time and bent the plastic tab on the Plastic float slightly, as it appeared to be a little high. While I had the carburettor off, I filed off the limiter on the idle speed mixture screw to allow fine-tuning. Adjusting the idle speed mixture screw had some effect but not enough to correct the problem.
A carby kit here in Australia is $74.
It has hydraulic lifters, so there is no valve lash to set.
I had considered that the fuel pump might be supplying too much fuel, but the float should prevent an oversupply if this were the case. I tested the fuel pump pressure at the carburettor, which is putting out 2.9 psi. I was unable to find the specs for this plastic manual pump. A new pump is $181.
Any thoughts?
Any thoughts?
