Hi all!
I'm helping a friend that was given an old Simplicity snow thrower with a Tecumseh engine that we have no info about.
I did the usual primary checks: spark, fuel directly into cylinder and got it to cough off. I then dunked the carb in the ultra sonic cleaner and we tried to start the thing. When spraying fuel directly into the carb it runs with good power but as soon as I stop feeding it it dies. I found an old carb that is the same with a little smaller throttle throat diameter and tested...same behavior, it starts and runs as long as I squirt fuel directly into the carb and dies as soon as I stop. I tried to cup the carb to force fuel to be drawn from the float bowl (which gets filled) but nothing.
I'm totally at a loss here. We know it has spark, we know that there is compression and obviously it has air. The only thing missing is the fuel...but why doesn't it draw it from the bowl with either of the two carbs? I have tried to see if there is any intake leaks but I can't see anything that indicates any cracks or bad gaskets. Also, when I cupped the carb there was pretty good suction.
We have ordered a new carb (Chinese from Amazon for about $10) but to me that's a shot in the dark since we tested two different carbs and there was no difference.
Any one with any idea what can be the issue?
Kind regards
Fred
Kind regards
Fred
