173d airborne
- Oct 30, 2023
- Threads
- 1
- 7
One ignition module was misfiring, replaced both ignition modules, ran fine then won't start. No spark from either module. any suggestions? HELP!!!
			Thank you, Will try that first thing in the morning. Just frustrating that it wont fire after it ran fine after installing the new modules.Check the ground connection first , then re install the module that was firing and see what direction that takes you , it's probably not a safety switch b/c it wouldn't even turn over.
