The bottom hole in the deck wheel bracket on my z540m is rounded and I’m unable to to tighten the 13mm nut without it spinning. I know I could move it up one but I mow between 3 - 3 1/2” height. Any suggestions on how to repair it ?
			There’s your answer. 3/4” off of the ground at 3” is too low. Raise those anti-scalp wheels. The bottom hole is when you are cutting at the highest deck setting. With the deck set at 3”, the anti-scalp wheels should be about 2 1/2” off of the ground. The anti-scalp wheels are to prevent the deck and blades from contacting the ground. They are not designed to support the deck.Installed new hardware and leveled the deck on the 3” setting. However, with the bolt in the bottom hole, the deck wheel is about 3/4” off the ground. This is as low as it will go. What am I doing wrong?
