Cub cadet zT1 zero turn won’t Stay running..again Help
4 yr old cub cadet will not keep running , stops when I pull arms up or engage blades . Changed fuel pump, new carb new gas new filters and it still won’t stay running when I pull arms together or engage blades I am about ready to sell it and get something different. Kohler engine 24 hp 54” does a wonderful job but won’t stay running
Sounds like the operator presence switch is engaging when it shouldnt.
Its the switch under the seat that shuts the engine off if there is no one in the seat. I have a ZT1 myself . they have been standard on all mowers since about the 80's . bypass it and see if that does it.
It didn’t work .guess I need to take it in to get it fixed then buy a book on lawnmower repair . Was hoping to not have to spend the few hundreds of dollars and time but I need to mow. Thx a lot
If you were trying the short across the wires it wouldn't work as the seat is a dual pole NC/NC switch. AND the wiring connector contains a shorting strip so you can't simply unplug it either.
I could tell you but as saying goes then I have to kill you. And just too tired to do it.
Beside it is a liability issue that I don't wish to deal with. Someone else here probably say it involves cutting a couple wires.
