LT2000 won’t start
jerrycmorrow
LT2000, type 917273760, Engine - 31H777-0297-E1
Went to run it and started and ran for about 30 seconds. Installed new Chinese carb last year and ran great all summer. Suspected condensation so took carb off and drained, cleaned with carb cleaner, dried with compressed air, reinstalled, put new fuel. No start
I’m being a little lazy plus my mower is stored outside, under cover, and it’s too cold to work on it unless I can zero in on the problem. Anyone can help?
mechanic mark
See page 15 in parts manual for carburetor overhaul kit OEM B&S Parts. Post your 8 digit Code Number from engine, thanks, Mark
Follows Code Number.
jerrycmorrow
Where on motor is 7 digit code number located not been able to find it
jerrycmorrow
model - type - 31H777-0297-E1
Code - 030918ZD
couldn’t see it cause last one had valve cover off put it on upside down. Thanks for y’all’s help
jerrycmorrow
This is the valve cover. You can see the code is not within the mentioned range
mechanic mark
If it is cold in your area & you are using 30wt. engine oil you will have a hard starting issue, switch to 10w30 engine oil. Check spark plug, air & fuel filters for replacement. Always use B&S OEM Parts for your tractor. Adjust valves with engine cold to specs. page 10 in Operators Manual posted above. Intake 0.003-0.005 Exhaust 0.005-0.007.
Watch youtube video below for valve adjustment procedure engine cold. Let us know if this helps, thanks, Mark
