I need help with valves?!!!!
RyanHL
I got a yth2348 husqvarna mower and the valves were way out of spec. so I readjusted them to .005". It ran for about 30 seconds just fine and went to the same old popping and hard to start. So i went back to adjust them and they were off again. Its on a Intek 23 hp Briggs. Im stumped on why it keeps moving. So if anybody could help me?
Give us the engine numbers so we know what type of valve train you are talking about.
RyanHL
Model 445577
Type 0755 E1
Code 070511YG
Check the rocker studs themselves as I have seen them to get loose and back out. Must be torqued to specs. As far as I know this is 150 in/lbs.
Gord Baker
Popping sound may indicate Lean fuel mixture or timing.
VRR.DYNDNS>BIZ
popping may also be 1) mechanical decompression if so equipped, 2) sticky valve. 3) head gasket, 4) plug/spark. Where is the pop showing - intake or ex? I also did not check specs against the model but all B&S I have done ( many ) intake and exhaust valve lash are not the same.
RyanHL
it sounded like both where popping but ill try with torquing the valve studs and dialing in the carb. Thanks for all the help. This is the first time I been on a forum and will use it more often
