troy-built
 - Sep 15, 2020
- Threads
 - 6
 - 120
Hi, Thank you that's what I was looking for a little input. It always helps when there is more than one person is thinking.We know why engine will not restart when hot
the problem is almost no one comes back with a
" the problem ended up being xyz, thank you"
so when others like you search, you see lots of suggestions but no solutions.
Without the engine right in front of us, all we can do is give you some tests to do .
You come back with the results of the tests then we can make a diagnosis
Only 3 reasons why a hot engine does not restart
1) bad spark
2) wrong fuel : air ratio
3) sticky valves
Having read through all of the posts and in particular the last one I would be looking at overheating .
So after 3 minutes with no airflow the carb has gotten so hot the fuel is vapourising in the float bowl or fuel lines
A lot of engines require a heat shield to prevent the fuel boiling in the fuel lines
{Without the engine right in front of us, all we can do is give you some tests to do .} That's all I was asking for. And I do understand about not having it in front of you I'm on a couple other forums and it's tough sometimes. But I always try to give Ideas what to look for.
Many thanks that has been very helpful.
