GAVolunteer
- Jun 28, 2013
- 38
Key in blade adapter ok??...it might be a key or key-way built in to adaptor
I believe I found the problem. The crankshaft is "a little" bent. I removed the blade and adapters to check the blade adapter key and pulley key. They were fine. After reinstalling the blade and pulley, I turned the blade several times and the blade bolt seemed to have a slight oval pattern. I attached a wooden skewer stick to the underside of the mower with the point of the stick centered on the bolt. When I turned the blade, I could see a small oval pattern of the bolt as it turned.
What is perplexing is that the flywheel key was not sheared yet the crankshaft appears to be bent. When the engine is running, there does not appear to be any vibration.
Would a bent crank cause the timing to be slightly off and cause a fine spray of gas to blow out of the carb?
This is a 1995 engine. Before I junk the engine for parts, I want to be sure that my diagnosis passes the "smell test". Any other tests or troubleshooting I need to do?
Thanks,
Robert
