If M and G are closed in the OFF position, then ign switch is working.
Bet the kill wire is grounded inappropiately (insulation worn off) between coil tab and ign switch.
I'd examine the length of the M wire on key switch to the coil tab.
If key OFF = yes grounded. If Key ON = no ground. If yes, bet the kill wire is grounded before key switch = bad.
Is there any way to test this nub (or is this the switch)?Those two ”nubs” are the connection points for the transmission switch.
Thank you for your reply.On these engines, every time the flywheel turns, it produces a spark, the 12 volt system is out of the loop, and if 12 volts is introduced to this tab, it will destroy the coil. So if the engine runs fine without the coil hooked up, then your coil is fine, and your trouble is somewhere else.
When the coil is grounded by the switch/system, then the engine shuts off.
Thanks, I'm aware of that! In the John Deere D100 manual, it strangely calls this button, the "RIS" button.Correction: (I thought the D100 had the CVT auto trans but it doesn't! No drive pedal!) Your engine will die the moment you shift in reverse (with the blades engaged) unless you press the RIO button first!
Explain, I am not following.. I tested it while switching between all the different combinations on the ignition switch.
