enginemagician
- Oct 29, 2014
- 2
When they fail with gas/oil mixture like they described the smoke billows out like a freight train.
Wouldn't that happen with the exhaust valve open, creating an easier path than around the rings?generally if the needle fails while the tractor is sitting, fuel flows into the intake and combustion chamber and past the piston rings,
Now, i will say i repaired a Kohler CV15 a few weeks ago, gas dripping out of the muffler.... needle failed and drained the entire gas tank, and i don't know how, but i checked the oil, the oil level was perfect, not diluted and didn't smell of gas..
how it didn't get past the piston rings, i don't know. however i did change it out to err on the side of caution, and it needed it as it was pretty dark./old.
Correct !! But...unless the needle failed and raised the oil level.
I agree with the people that are saying NEEDLE , Or there is some varnish / gum build up on the seat. those VITON tips on the needles are etho proof so says the company......... A combo of seat and head gasket is suspect.....I watched the video again. No way a carb needle can do this. Smoke color was a tremendous blue/white smog.
Carb needle flooding the cylinder would be blowing black smoke, chugging all the time. Just like running it with the choke on but way more severe.
It’s definitely your needle or seat, I’ve had mowers come into my shop with the same problem many timesI put a new B&S engine (INTEK 17.5 HP - Model 31R907-0006-G1) on my Snapper riding mower 3 years ago. All running great until today when it started BLOWING SMOKE..... a lot of smoke. Pulled the oil dip stick and smelled of gas. Changed the oil and blew a small amount of smoke on first start. Second start had no smoke and runs smooth. Any advice on what's going on here. Here's a link to a You Tube 20 second video showing what's happening:
Be sure to check the float also, it should not have any gas in it, shake it to make sure, if gas got in you have a crack in your float which will not let it float correctly and set the needle in the seatIt’s definitely your needle or seat, I’ve had mowers come into my shop with the same problem many times
Where can we purchase non-ethanol gas? Second question: Is stabilizer necessary for non-ethanol gas stored in gas cans for 1-3 months?Yeah unfortunately these are pretty junky engines. Camshafts love to come apart and yes head gaskets like to blow too. The Nikki carbs are a PITA. Hard to work with and fail a lot. I try and find Walboro replacements when available, or I buy aftermarket eBay carbs. No sense in spending 120 bucks on OEM when they’re leaky low quality anyway. Ethanol is known to deteriorate rubber, and the Nikki carb has that giant o-ring thingy as well as a needle seat made of rubber. I have seen what ethanol can do so I avoid it personally, whether or not it’s the sole cause of carburetor failure. Could be entirely wrong but non ethanol gas is only a bit more expensive so no harm done.
But in OP case, the oil smelling like gas and being too full before changing, and the fact that changing it solved the problem (for now), that basically guarantees his problem is needle and seat.
